steve earley
- Joined
- Mar 11, 2013
- 3
I've got a Nissan two stroke 3.5 hp with a long shaft about eight years old. Pretty well maintained. Water impeller kit has been installed twice over the years. Steady stream of water when new, declining to a steady dribble when impeller has a couple of years on it. Used first time on the water this year yesterday. No water at all dripping out of the tube. I only had it running a couple of minutes (sailing the rest of the time), but did not like seeing the lack of water.
At home today tried to run water through the system. It would not go. Tried to blow air through the tube, it would not go. Took off the lower unit and tried to force water up the tube and it would not go. Used wires to run in through both tubes to clean them out. No improvement.
I've clean what I can, but I am not sure of the water's path in the upper unit. What should I do next?
thanks a bunch
steve
thanks a bunch
steve
