I was reading a prior post stating copper head gaskets shouldn't be used with an aluminium head or block.
last year I replaced the head gasket on my 1998 25hp Evinrude twin. During assembly I noticed the head bolts had sealant on them from the factory, so I cleaned them off and sprayed on fresh coat of copper gasket sealent on the head bolts. I also sprayed a thin coat on both sides of the head gasket, the head and the block, Where they mate with the gskt.
Is this going to be a problem? Do I have to worry about excessive corrosion even in fresh water?
