circle hook
- Joined
- Dec 6, 2007
- 271
do cork floats go bad even if they look good I set the float level at the spec. called for but still keep having the carb flood out it has a new needle valve & seat, also the fuel by all right should shut off. and the high and low speed needle valves look good and are also set to starting spec, 1 turn on the low and 2 turns on the high. and she still floods. what could be the problem Thanks Bob
