Re: correct anchor size 28 Voyager
I have an 1988 28' Carver Voyager and I use a West Marine "Traditional Anchor" 22lb. Stock# 439950 $67.00.
My water is mostly small rocks, lobsta traps and mudd. Holds well. The only thing I would change is to drill a hole in the front of the anchor and lift from this when I bring the anchor back up instead of trying to pry it out of the mudd. Seems if you pulled on the top it would back out instead of ripping up what it's hooked to..
