correct beep sequence on 1989 Mariner 115 hp outboard?
exnavyman123
I recently had a beep beep alarm, the oil sensor on the bottom of the outboard mounted oil tank was loose, i could pull the long plug type sensor that has the two blue wires down a bit and it stopped, i ordered the new tank and sensor and the oil control module, i was wondering after these new parts are installed what is the correct beep(s) i should hear when starting the motor?
Thanks
