Correct electronic ignition module for a 1991 Mercruiser 5.7L Ski engine
sirket
I've been checking on the iboats web site and they list two different electronic ignition modules for the same year Mercruiser 5.7L Ski engine (neither of which match my serial number as best I can tell). Pertronix only lists one module for any year 5.7L Ski.
Does anyone know which electronic ignition units will fit this engine?
Thanks.
Don S
Re: Correct electronic ignition module for a 1991 Mercruiser 5.7L Ski engine
What is your engines serial number?
Don S
If the module is mounted on the exhaust elbow, the Oem number is 821125A1
If mounted on the distributor, 805361T6 is the one you want.
sirket
Sorry- I believe I accidentally misled you. This engine currently has a points system- I'm looking to convert this engine to an electronic ignition. I'm trying to figure out what _conversion_ module would fit in the distributor of this engine. Sorry for the confusion.
sirket
Does anyone else have any idea what electronic ignition conversion module would fit in the distributor of this engine?
