Correct fuel pump to use
F_R
Re: Correct fuel pump to use
Nope, you want the 18-7351 to get the correct hose sizes.
http://www.iboats.com/Sierra_18_735...4870548--**********.472386457--view_id.174140
EDIT: On second thought, look at your motor and see if there is room for the hoses to exit the bottom of the pump without interference from the lower cowl. The big inlet fitting can be rotated to any position, but you are stuck with the outlet fitting pointing straight down. You can't put it on the top bypass cover on that year because of the drain hose goes there.
If there is room, it is a great pump to use.
rich64
I have a 1975 Johnson 25 hp and was wondering the same thing.Right now it has the square 2" fuel pump on it.
tashasdaddy
as F_R said if there is room.
jethro66
Ok I will buy it from here,thanks guys!!
rich64
75 johnson 25 hp is different than a 76 all I've been able to find is part#388685($88) and it seems that there is no after market replacement.Having a hard time even finding a rebuild kit. Any advise would be very helpful
F_R
Rich, the square pump sold here will work. The only difference is the direction that the fittings point. OK, you may have to take it apart and reassemble it in a different direction, if necessary. Both fittings can be repositioned. I believe the instructions have been posted here. If not, try
http://www.sschapterpsa.com/ramblings/Rebuilding_fuelpump.htm
Edit: If little springs and tedious parts scare you, better pay the $88.
jethro66
One more question,does 18-7351 fuel pump have to be mounted on the bypass cover in order for the pump 2 work?Need longer screws..
