Correct hub kit for SS prop/Volvo SX drive
bunker108
I bought a used SS prop for my SX. The guy told me it was off and SX, I looked at his boat and drive...it looked like an SX. But it is now obvious that it was actually a 15 spline OMC because it doesn't fit my 19 spline SX. So now I need to re-hub the prop and want to make sure I don't buy the wrong thing again.
The prop is 14.5"/19p. The only numbers stamped into it are 8661 which I can't seem to identify with a manufacuter. The hub is 4.5" long and measures 2.5" on the drive side and 1-3/8 on the nut side.
Can anyone tell me which hub kit I need to fit my SX drive? Also are there any tricks to pressing the old hub out and getting the new one in?
Thanks!
Re: Correct hub kit for SS prop/Volvo SX drive
Thanks!
Ayuh,... If it's the ole style pressed in rubber hub,... Ya need to take it to a Prop Shop to change it....
If it's the new style plastic multi-piece hub,...
Ya, just buy the 1 ya need, 'n change the splined thrust connector...
bunker108
This most definitely has the old style pressed hub. I have a press, should I not attempt to press the old hub out and a new one in? I was hoping to purchase the correct hub and install it myself since I already threw away money on this one. I just want to cut my losses at this point.
So how can I figure out what hub I need? Are the props all fairly universal?
Ayuh,.... That seems to be the big secret in the prop repair industry....
bunker108
I pressed the old one out...that was easy. Now I just need to find which kit to order.
bunker108
Ok, I think I found the right hub. Solas part #VE-RB-1. I am going to get one coming and press it in myself. I will post my results.
