My engine is 40hp 1984 Evinrude electric start with single lever OMC control box, there is a rubber tube affair attached to the ignition key which when pushed in chokes the engine, but what really is the correct method of starting, should this be pushed in and held while cranking or pushed in just once and let go, or used each time whether it is hot or cold and should this be used with warm-up lever in up position? I flooded the engine yesterday and don't know if it was due to overpriming with the primer bulb or what I was doing with the starting procdure? can it be overprimed with the bulb? thanks for any help. JBD
