Re: Correct Position
Here in Trinidad we rarely see rollers on trailers, unless its an imported trailer from the USA. we have boats with pretty deep Vs and almost everything under 30ft is stored on a trailer. just resting on the bunks. wooden and fiberglass boats. Including my imported from USA road trailer with a 10,000 lb boat. so i would say since the rollers are there, it wont hurt to push them up to contact the hull, it would be cheap insurance if one of the bunks fail for some reason, but it is not really a requirement, once the boat sits squarely with the strakes on the bunks. i.e. the trailer is properly adjusted for the boat. Also if your boat is loaded a bit too much to one side, which it should not be, the rollers in contact will help it get on the trailer properly a bit easier. but the rollers do not need to share the load.
