The one that under any load, light or heavy, allows the motor to reach maximum ...RATED rpm... Hopefully your motor has a R P M Limiter.
Other wise, you need to have a GOOD hearing memory, of the correct R P Ms. That means using a temporary tachometer to memorize the pitch.
