Re: Correct Prop
An older 25 horsepower Chrysler should use a 9 X 10 inch pitch prop. On my '70 something 25 HP Chrysler I am using a 2 blade 9 1/4 X 11 pitch prop. This is on a 10 foot tunnel hull racer.
I'm not too sure about the '80s but the older Chryslers had a different sized prop shaft and the 10 3/8 prop would not even fit the 25. However, even if it did fit because they changed the shaft size, that's still too much prop unless you are pushing a VERY light boat--like a 12 foot aluminum jon boat with nothing but yourself, a 3 gal. gas tank, life vest, anchor, fire extinguisher, and paddle.. The thought also occurred to me that if your boat is rated for 25 HP, perhaps the previous owner changed the decals and you really have a 35, 45, or 55. So yeah, I would say the prop you are now running would usually be used on the 55.
Look inside the lower pan for an aluminum plate bearing the model number. The first two numbers of the model--not serial--will be the engine size.
If that is the correct sized hub and shaft, and if the engine is indeed a 25, a better choice would be a 10 3/8 X11 pitch prop.
You have really piqued my curiosity. Is it possible to post a photo of the engine? Thanks.
