Hi all - my 93 v4 has what looks like standard grey yammy fuel line plumbed up into the carbs and from the engine. It does not have a fitting in the cowl - is this normal?. It looks like 5/16th - I thought it would have to be 3/8th. I have run 3/8th to it and a large (3/8th fittings) tempo (USA) primer bulb. I notice that it primes quicker than the old set up of small bulb and 5/16th line - but only to the point of meeting the smaller diamter hose I guess - can only flow as fast as the smallest opening allows it. Does the Yammy come standard with the larger diameter?<br /><br />Next question - why does the oil buzzer come on if I leave the motor tilted (fully or so)_up for some time before start up (when lowered). Is it because the oil level float in the engine tank needs to settle down.<br /><br />Cheers mates
