I am planning to re-upholster my 1985 21’ Chris Craft bowrider this winter. (350 I/O Mercruiser) I’d like to build wrap around seating on one side and a solid upholstered side panel on the other side (instead of the open storage areas that are there now). As is, there is lots of added airflow into the engine compartment through these side storage areas while underway (in addition to the vents from the outside of the boat)
So my FIRST question is... Is it ok to block this airflow from inside the cockpit with panels and seating?
I know there are lots of runabouts with engines tucked away, completely seperated from the cockpit. I just want to make sure what ever I do is safe.
2nd question... If vents alone will be sufficient ventilation, what is the correct layout? Both my vents have openings facing aft. The starboard vent has the blower and hose goes down into the bilge, under the engine. I assume the port vent should be facing forward to act as an intake. Am I correct? Is it installed incorrectly on my boat with both of them facing aft?
