My Boat is a bit Newer and set up for Larger Motor Than I have.
Facts:
1. The Nose Cone of My Boat is Barely at the Bottom of the Center of the Transom.
2. The Propeller Creates a Large swirl of water and while running you can see where water isnt even touching the motor shaft a good ways down
3. The Smaller The propeller the Higher RPMs are before i get the spun prop effect (per say)
I can Not Lower the motor down any further, at 1/2 or a little over 1/2 half throttle with smaller prop I get the spun hub effect.
Questions:
1. Would dole fins correct this issue?
2. What position in relevance to the transom should the cavitation Plate be
3. Would adding fins up on the motor to maybe the splash guards help any?
4. please reccomend the Best possible solutions?
Facts:
Questions:
