The petcock water fitting on the block is built up so as I can not reinstall the petcock .
Is there a way to loosen this residue other than tap and die !?
1989 4.3 L alpha one.
1/4 NPT
In the future, when winterizing and you remove the plugs to drain, put the plugs back in so the threads don't get all rusty.
Put a spot of gasket sealer on the plug. More for corrosion resistance than sealing the threads.
