Corrosion around engine gaskets
SPYKE-KPT
I have a 200 yamaha efi and while getting it ready for the summer I noticed white powder at the bottom of the engine housing. It was coming from around the head gaskets. Is this normal?
Trent
Re: Corrosion around engine gaskets
Normal for a saltwater engine.
deejaycee_2000
Flush your engine properly with fresh water after use to keep it from getting worse ....
SPYKE-KPT
The boat is moored in the ocean so I cant flush it with fresh water.
rodbolt
then watch it corrode away I guess.<br /> keep the powerhead sprayed well with fluid film. but with ocean salt and no flushing look for failures in 6-8 years.
deejaycee_2000
mmmm then you have a problem, geuss you will just have to be prepared to change motors every couple of years ...
