83Evinrude
- Joined
- Sep 3, 2008
- 290
In the step below from Don S winterizing post what does everyone use for this?
Does everything mean the entire engine block? Mine is pretty clean and I'm worried about attracting dirt, its only used in fresh water btw.
"15. Spray your favorite corrosion blocker on everything (except fiberglass).including the battery terminals. Turn the steering so most of the rod is extended, make sure it's clean and spray it with a light oil, turn it back and forth a few times spraying in between so it's well lubed."
