Howdy all,
As my first post to IBOATS, I need help! I hope to repay the favor as I gain more experience working on motors.
Here's the deal:
I have an old Honda BF100 (pre-1997, but not sure exact year) 10HP outboard. Bought it last year along with a 14' MirroCraft and it has been running very well. However, from the beginning I've noticed that the cooling pee stream is relatively week compared with other motors i've run. So, recently I pulled off the lower unit to inspect the impeller & housing. Turns out the impeller is in great shape, but I found significant corrosion in other places--mainly where the lower unit meets the impeller housing and "key-shaped cover". There is major corrosion just under the impeller adjacent to the shift linkage and also where one of the bolts screws in. See attached photos. Note that I've run this motor in salt water quite a bit, but have always flushed it with fresh water.
Being a novice boat mechanic, I have the following questions:
(1) Could the corroded-gap under the impeller housing be causing the water pump to lose power, thus the weak pee stream? It seems like the pump would be drawing air from the gap, thus decreasing water draw.
(2) What other problems, in any, could it be causing?
(3) Is the lower unit effectively screwed due to this corrosion, or can I clean it up and plug that gap with silicone (or something else)? Eventually, I'm going to buy a new motor, but would like to use this one for at least one more season since it runs like a champ.
(4) If the lower unit is screwed, does anybody know where I could find a replacement? Used is fine. Roughly, how much would it run? Couldn't find any on the internet, but have yet to check with my local Honda dealer.
(5) A rubber gasket where the impeller housing meets the lower unit is also degraded, but I can't find that part online? (see 1st photo) Does anybody know how to find the Honda part number on that? What is that gasket called?
Thanks in advance for your help,
Wild Oar
Here's the deal:
Wild Oar
