Re: Corrosion
The electrical grease or di-electric grease is usually available from an auto parts store. Regardless of where you buy it, ask if there's another choice. Ot one parts store I frequent they have no less than four different products from three different manufacturers. It can get very expensive. I usually get a large tube and it costs me $8-$9.00. Meanwhile, if I just tell the counter person I need dieelctric, I get a tiny tube for $4.00.<br /><br />But di-electric grease is a special silicone grease. It will prevent water intrusion and consequently stave off corrosion. The connections must be clean and dry first however, because the grease does not displace water. Use this stuff and forget about corrosion. You will probably hav eto reapply it periodically also. Good luck and happy fishing.
