Re: cost of rectifier
According to Joe Reeves<br /><br />"Remove the rectifier wires from the terminal block. Using a ohm meter, connect the black lead of the ohm meter to the rectifier base (ground), then one by one, connect the red lead of the ohm meter to the yellow, yellow/gray, then the red wire (some rectifiers may also have a yellow/blue wire. If so connect to that also). Now, reverse the ohm meter leads and check those same wires again. You should get a reading in one direction, and none at all in the other direction."<br /><br />I get readings in both directions so I guess it's bad.<br />I did buy the radio shack rectifier, but I don't know. Replacing a heavy heat sink with a thin silicon wafer??? I can get a used one for $50 and it's guaranteed to work so I think I'll go that way. Thanks for the help guys, amazing what pictures can do. I'll let you know how the "new" one works.
