Jon Boat Jim
- Joined
- Mar 19, 2011
- 75
My 1990 TJ25ELESE 25 HP Johnson is suddenly coughing and dieing. It starts fine, idles OK (a little rough) but when I increase the throttle it coughs and quits running. I limped back to the dock at idle speed yesterday.
Today I checked the plugs (OK) and compression (OK). Then I switched to a new gas line that I knew was OK and then changed out to a different gas tank. Nothing helped. I also inspected the fuel pump screen to see if it was blocked (it appeared to be OK).
The motor just will not run when I try to open up the throttle.... a big cough and it quits running.
My shade tree mechanic diagnosis is that the problem has to do with the high speed orifice/jet. Do you agree?
Can the orifice be accessed without taking the carburetor off?
