Joe_the_boatman
- Joined
- Apr 14, 2005
- 482
EDIT: [Scroll down for test results]
'85 60hp 2-stroke. I'm beginning to think my bogging problem isn't fuel related, since I've replaced just about everything on the fuel side.
Motor starts and idles fine. Hit full throttle and RPM's jump to around 5K for a few seconds, stumbles a little, then 4K (still at full throttle) and then engine quits unless throttled down, or it may jump back up and then quit. Idling or running slightly above idle the engine runs fine, and gets me back to the dock.
Sounds like a fuel problem, right? Carb bowls have lots of fuel in them after the engine shuts down, though. Pump, carb gaskets, needle valves/seat, fuel lines and filters have all been replaced. Carbs dunked and reassembled, floats set at 11/16", then link'd-n'-sync'd. Timing's 4?BTDC @ 800 RPM. Running Autolite plugs now. Engine missed and stumbled big time when I put NGK's in (weird, I know). Runs great w/ Autolites though. Mixture screw is set where richer or leaner causes idle RPM's to drop (about 3/4 out).
Any ideas? I would think a bad ignition wouldn't let this thing run at all, but again, it starts and idles (trolls) fine.
