Re: Could be very bad idea?
So what is going on that your doing the tests? While your at it check the diaphram and check valves.
Do a compression test just for fun.J
Surging in the midrange. The motor will run fine at WOT or at low speeds. Surges, sputters, and smokes like crazy anywhere in the middle. No idea what it is. Is there something that could make the motor run rich at midrange?
Compression test was solid, a little over 140 for both cylinders.
Carbs are clean and freshly rebuilt.
Diaphragm looks new since I replaced that not so long ago, valves are all opening and closing back up.
Reed valves are not stuck and are flat.
Am getting spark to each cylinder.
What the heck could it be?
It's already running off a portable tank. The contact point between the nozzle that the fuel fitting goes into and the tank seems to be loose though, unlike the nozzles of the new tanks I see. Air leak there? Replace it? I am tired of throwing money at random parts hoping it'll fix things though..
