olddogmike
- Joined
- May 25, 2003
- 39
I replaced my engine coupler in May and now, after only 40 hours on the water the engine rpm's are climbing and speed is falling off again. I did purchase and use the alignment tool. The tool went through the gimbal and into the coupler with no problem. The outdrive slid into place and faced up on the transom without a fuss. I noticed that the engine seems to surge at around 3200 rpm and then loses speed as the rpm's climb past the 3500 marker. I am wondering if there could be something in the outdrive that could be the cause of this problem. Could a fouled bottom or lower unit contribute to this? As always, much obliged for your input.<br />Thanks to all.
