Could I be having soloniod problems?
OHBABE0123
I have a Johnson Outboard 25 horsepower motor model # J25elese and serial # Ros537444<br />The starter motor free spins and doesnt jump up into flywheel. Could this be a solonoid problem? Also anyone who knows how to tell me what year this is, I would greatly appreciate it.
Beaux
Re: Could I be having soloniod problems?
one of two things usually cause:<br />(1) starter drive could be corroded or need lubrication<br />(2) starter is not producing the necessary speed and torque to engage the drive. <br /><br />If it is spinning, at good/fast rate, the solenoid is working.
Bear
Johnson 25HP electric start, long shaft, 1990.<br />Check and charge your battery.
gee gee
make sure battery is fully charged.clean ground/postive cables[wire brush] from battery.connections must be clean and tigth to make circut.
Beaux
maybe i read your posting wrong :eek: , does it spin freely by itself when you turn the key but not jump up and engage the flywheel? Or does it just spin free with your fingers but not do anything when you turn the key? My answer relates to the first scenario .. Good luck
