kaltireman
- Joined
- May 5, 2002
- 20
mariner 30hp approx 1990 model 30eo 689 s serial#250287 electric start<br />I haven't used my boat since it let me down last year(bad gas issue) I sprayed carb cleaner in the carb and ran it, it wouldn't idle so i adjusted a small screw on the starboard side of the carb near the top approx 3/4 turn out(it was only 1/4 turn from being all the way in) the engine idled and came up when i hit the gas. today I hit the lake and the engine ran fine high speed slow speed stopped the engine and restarted it everything was great after about a half an hour and running at full speed she began to lose power and sort of rattling(don't know how to explain it) tell tale was spraying water didn't seem overly hot waited for a minute then restarted it had to give full throttle to get it going would not run good at ful throttle so I headed for the lauch at slow speed half way back i tried it at full again it was Ok for a few minutes the lost power and rattled again so waited and restarted chugged along for home. when i was almost at the lauch i gave her again at it lost power and died it did want to start very sluggish on the starter which never happened the other times so my buddy was about to tow me the last few hundred feet and I got it going. Brought it home and it runs not badly in the driveway with the muffs on any ideas PLEASE HELP KEN COULD IT BE AND ELECTRICAL PROBLEM AND NOT THE CARB AT ALL??
