jtexas
- Joined
- Oct 13, 2003
- 8,646
This is a 1979 'rude 70 on a 15ft fiberglass bass boat.<br /><br />My trailer had to make a sudden stop recently, and the boat moved the bow stop forward about 3" causing the transom saver to force the outboard up a bit. <br /><br />There's no obvious damage, no broken parts dangling or anything, and the TNT works and sounds exactly the same as before, but I noticed the motor lifting itself a few inches when motoring off the trailer in reverse. <br /><br />There's a few inches of play to where you can lift the motor manually just a little bit when it's on the trailer. I don't exactly remember if it was that way before, but I never noticed the motor picking itself up in reverse before. <br /><br />Is it possible that the bracket needs some adjustment or repair? <br /><br />Also, I have the nagging feeling that the bow is riding lower than before - could be my imagination, though since I have no tach or speedometer, but I feel I've lost just a bit of speed. I'm wondering if it could have something to do with the bracket question.<br /><br />thanks,<br />jtw
