Could someone identify this tilt & trim...??
mrcj001
The engine is a 1975 Johnson 135
The T&T thats on it doesnt look like the one on the BRB site.
This tilt and trim seems to have two motors one on each side.....
its working, just need some info on it....
ezeke
Re: Could someone identify this tilt & trim...??
The assembly on the port side is a Power Lift Kit [No Trim] sold for 70HP & 75HP Long and 85HP, 115HP and 135HP motors 1972 through 1977.
The part number is 172189, 172509, 172485 or 172594 apparently depending mostly on the year.
willamettejeff
What you have there is 2 different units. 1 to tilt the motor, the other is a jack plate that raises & lowers the motor to adjust the depth of the prop in the water which effects performance. As was stated, that style tilt unit was used up through 1977.
mrcj001
It only has a "up" and "down" button on the control, which tilts the motor...does the "trim" function at the same time??
