1992 Johnson 150 hp
TJ15OGLENC
I'm working on this motor that is giving a slight lean sneeze at idle, and at trolling speeds in the water. It will slightly sneeze, but only when in gear and at trolling speed. In other RPM ranges, mid to WOT it will run great.
I've gone through and cleaned all 6 carburetors, paying close attention to the idle circuit and all the small passages. I'm sure the carbs are clean BUT what I found looks like worn rubber covers that go over what I believe to be the idle circuit. Could this seal be letting air in from somewhere whether from outside or within the channels causing the engine to run lean if it wasn't installed in the exact same spot it was before? Here is a pic of it:
TJ15OGLENC
