iloveketchup
- Joined
- Dec 4, 2010
- 54
through trial and error, and a lot of going in circles in reverse providing quite a lot of entertainment for passer by's i've determined the gearcase on my apparently 1978 140 crossflow is counter rotating. Meaning if i put a common Right hand prop, if i try to shift into forward, it goes reverse.
This is a problem as although i can just kinda use the controls as is, with a 13x19 right hand prop, the motor will only get up to about 3800 RPM as the actual stroke in the control arm doesn't go as far in "normal" reverse (forward in this setup). Essentially if i were to gun it in reverse the boat could potentially go faster than a normal setup as "normal" forward has more travel.
The solution is to get a 13x19 left hand prop for this gearcase however they are expensive as i've only found them to fit in stainless for around 250 - 300 with hub kits.
I confirmed a few years through shop.evinrude.com (parts catalogs) OMC/Johnson/Evinrude did make a reverse gearcase.
Question:
What was the reasoning for making the counter rotating gearcase? Are they at all rare or more valuable than the standard?
Question:
