First, thanks for all the insight that is accumulated here - just did a minor overhaul and I have never even attempted much more than a plug change (manual helped too, but a ton of great info here). Dont know alot about this motor, just kinda fell into my lap.<br /><br />It is an Evinrude 18hp 1959 model 15028.<br /><br />1) I dont know where the "pee stream" is on this motor, I have it set up in a trash can and the water is about 3" above the cavitation plate - is that enough? I ask because I dont see any water flow from the engine - only a bunch of turbulence where the intake looking thing is above the prop. I start her up just fine, but am afraid to do much more than that for fear of breaking something. It has a new thermostat by the way, impeller, etc changed.<br /><br />2) When the throttle arm is cranked all the way up, the butterfly in the carb is supposed to be horizontal correct? I ask because it is barely even moving at wot. I have read about the synch and link - but it seems like the throttle arm is moving when it is supposed to - at the center of the mark.<br /><br />Thanks!
