The Force isn't bad, but it has given me starting issues and is sluggish coming out of the hole. It should be able to rip the skiers arms off, but it's slow getting out towing someone. It runs fine at WOT, revs properly, but starting and the hole shot need some work. Thinking of replacing it, but if I can pinpoint the problem, would like to fix it. Any suggestions? I went and cleaned the poles from the battery, both ends, checked spark plugs. That's about as far as my "engine knowledge" goes.
Also, I have this engine on an 18' Maxum bowrider, the boat is rated for 125hp. What's the biggest sized engine, horsepower wise that I could replace the Force with? Say, 130, 150, 225?
Thanks for your help guys and girls, this site is unreal.
SSS
SSS
