1987 US Marine Force 50
I've been having issues with my boat starting (starting to wonder if the battery cannot deliver enough amps). The starter will engage the flywheel and turn it a little. So I took apart the starter just to have a look-see. Should I just be able to clean them up based on the pics?
Also, the ground wire that runs from the solenoid to the distribution panel attached to the engine block is now smoking and melting when I try to start the motor. I checked the resistance of the wire with an ohm-meter and it is at 0.00. (This ground wire also connects with the battery ground wire at base of solenoid.) Any thoughts?
