OK....tomorrow I start the project. I have a 98 searay 3.0 i/o. I will be replacing the coupler and doing the bellows/gimble bearing.
I have a new coupler that was given to me with the used outdrive I purchased. My question is, The coupler is triangular, but it does not have a grease fitting on it, will it still work on my gen II unit.
Also are there any secrets/shortcuts to changing the coupler? Obviously the drive is already out. What is the best way to do it? My plan was to unbolt the lags from the stringer, unbolt the rear mounts, disconnect anything in the way and lift and turn the motor to access the coupler without completely removing it. Will this work?
Also for the bellows/ gimble....Pull the hinge bolts and seperate the bellhousing? or is it possible to replace them while they are still bolted together?
Any advice will be greatly appreciated......my wife is breathing down my neck to finish this darn thing.........
Thanks.
Thanks.
