Coupler
Dan01543
Hi I was wondering what would work really good to clean the splines in my engine coupler. I noticed there's alot of old grease and other stuff that's kinda hard and I wanna get them splines completely clean and re-greased before putting my outdrive back on. I have a feeling that's why I have a hard time putting my drive back on.i have a new driveshaft and when I just slide that in the coupler it goes in a little hard.so I'm thinking it's old grease that has broken down over the years and turned a little hard and now I have Resistance when slide the drive on.
Thank you
Horigan
Brake cleaner would work well, as well toothbrush on a stick.
Have you checked for proper alignment with an alignment tool? If it’s out of alignment, it would have similar symptoms…
Scott06
X2 on checking alignment
Why was the driveshaft replaced? If due to wear on splines coupler may be roached too
BRICH1260
You might try something like a curved dental pick taped to a dowel rod. Reach it up in there and try to break up any old grease. An occasional spray of brake fluid to further break things up and flush it out.
