covering a boat for winter
pwpns
I was wondering if it would be better to use a boat cover or a tarp to cover a boat that will be stored outside for the winter. I have heard that a boat cover will let the cockpit breath and not ruin the carpet and vinyl. But a tarp would probably help keep water out better. Just wondering if what everybody elses thoughts were on this. Thanks
Isaacm1986
Re: covering a boat for winter
I use a tarp and it has worked great for me.
dachief
I just bought a cover from iboats today got 70% off and free shipping. This is a good time of year to buy one.
generator12
I've always used covers - canvas or synthetic. Canvas, of course, must be sealed or it will drip melting snow into the interior all spring long.
The first couple of years I stored it in the yard beneath the trees. I learned (the hard way) that tree sap will drip onto it and cause holes. I've been told that it is acidic. The effect sure looked that way.
Also, I've never had any luck with the poles that stand on the deck and hold up the middle of the cover. On each of the two boats I've had (open bow runabouts) I've made up frames, either free-standing or which lie across the hull, out of 1/2 inch thinwall conduit (about a buck and a half for a ten-foot length at a hardware or electrical supply store) to hold up the cover - one for the main cabin and one for the bow area. These have kept the cover from supporting the weight of the snow and sinking into the hull. They're galvanized and last indefinitely - one set worked for over thirty years and was still effective when I sold the boat.
If interested, send me a PM and I'll forward a couple of snapshots.
bajabuddy
Or you could use your boat cover and put a tarp on top of it.
roncoop75
Where are you at? Around here most covers don't fare to well over the winter. I use two cheap plastic tarps. By spring, the one on the outside is pretty much junk and gets tossed. The one underneath is next years outer cover. The summer cover goes in the basement in the winter.
DBreskin
I use a tarp. I made a simple frame for my bowrider to tent the tarp over the boat. The peak is high enough for snow to fall off, and the ends aren't sealed tightly so air can circulate and keep the boat dry inside.
A tightly fitted boat cover will keep water out, but may also keep moisture in.
dingbat
Contrary to popular belief, tarps are porous and breathe just as well as a boat cover. ;)
