Crack in aluminum on my outboard
b.orear
I have a small crack in the aluminum housing on my 9.5 evinrude outboard. I am thinking of using a cold weld compound like JB weld to fix it. Does anyone know if this will be sufficient?
dkondelik
Re: Crack in aluminum on my outboard
'mornin' "b",<br /><br />Which housing are you speaking of? I presume you mean the "clam shell" that mounts around the power-head & leg? if "yes" then the question becomes "where is the crack"? if it is in a stressed area, i would recomend getting it welded. if it is not in a load bearing area, then maybe JB Weld is ok but even at that, you ought to consider drilling out the end of the crack to prevent it from progressing.<br /><br />Good Luck
