Crack in crankcase after driving out taper pin wrong way on 1974 Johnson 50
jtrom
So I screwed up royally driving out the taper pin the wrong way and a small crack formed on the boss as seen in the pics. Anything I can do here? JB weld? Do I really need to do anything as its not a stressed area? Thanks for any insight!
interalian
Check the mating surfaces are still flat and parallel after the pounding.
Bosunsmate
yeah dont worry too much as you say its not in a highload area and its well in from the seal, just do as suggested above
Chinewalker
It's on the outside edge, well away from the spaghetti seal area. I think you'll be fine... As noted above, check for distortion to make sure it didn't throw things out of whack.
