Cracked bell housing
Status
Not open for further replies.
gregskjei
I have a 4.3 mercruiser with Alpha One outdrive.
There is a crack on the bell housing (see picture).
This on the flat part of the housing on the starboard side, about 1" above the bottom bolt. The crack is even with a cable going through on the inside - I think it might be the shifter cable?
Is this a major problem requiring replacement of the bell housing?
Can the housing be repaired/welded?
Can I run the boat or will I cause more damage?
Also, I have no idea how this happened. I have not struck anything in the water. I did put a hydrofoil on - could this have stressed the housing? Also, it's getting colder here - could it have filled with water and froze?
Re: Cracked bell housing
Ayuh,...
I believe that's right opposite the shifter cavity,... I don't know Why it might have broke,...
But,..
I would think that a used replacement would be what I'd do,....
I really doubt that Welding would be a viable option,....
Used are pretty plentiful... and because of that, Reasonably Cheap....
Btw,....
Welcome Aboard.....
gregskjei
Thanks for responding :)
If I run it like it is, am I risking internal damage?
Ayuh,...
You Risking allowing Water, where it Shouldn't be.....
Continuing to run it, will potentially only elevate the total repair bill....
krisnowicki
whiles you are swapping it out might be a good time to change the bellows and what not too...
Status
