I'm new to working on boats. I was given a 1989 Searay with 3.0L/130 (181 cid) motor. When I received it last fall, it would not crank, so over the winter I rebuilt the carb. This past weekend I finally got it all back together with fresh gas and managed to get the boat cranked. Here is a link to it running. Unfortunately, when I looked in the engine compartment I saw water. Here are a couple of links showing the water leak (link1 and link2). I can't see exactly where the water is coming from, but is there a hose or something that is fixable back there that might be leaking. The leaks seems to be behind the distributor. I'm hoping so and that it is not a cracked block.
