Hey all,
It's been a while since I posted. Im back.
I have a 1979 120 Merc. (153CID).I have restored the boat after getting the motor running good on the ear muffs, but when I put her on the water not only did I find a hole in the oil pan it was leaking oil the color of chocolate milk. we got here back and I drained the (oil all milky brown)out. After reading several post on the subject Ive come to the conclusion that the block may be cracked. I did a compression check (150psi across the board).
So Ive pulled the motor,dropped the pan ,pulled the push rod coverand the manifold. I havent been able to find a visible crack.I pressurized the water jacket and can not here any "hiss".I did find some deposits that look like rust sediment in one side of the intake port.If the manifold is leaking water into the intake, could this put enough water into the crankcase to turn the oil? The motor appears to be in great shape inside, no signs of wear. Have not pulled the head yet but plan to if all else checks out.
Any insight anybody?
Any reliable way to check for block cracks? (when the motor is out). Thanks for any help!
