I have a 1990 40hp twin Evin. This motor had low compression on the bottom hole. I tried to remedy the problem with Seafoam, hoping it was just stuck rings. No luck.I removed the head and found that the #2 cyl was all scored up and the piston was shot. No real problem for me. Then I noticed that the block was cracked between the cyl sleeve and the water jacket. I thought this motor was toast at this point. I called my Outboard machine guy. No problem, he cut out the old sleeve, welded up the block. Bored out the block,pressed in a new sleeve. Bored both holes .020 over. This work turned out beautiful. I assemembled the powerhead last night. I am going to finish assembly and tuning today I will post the results.
