Re: cracked block
I prefer stitching or lacing of the block only if the crack is external. If the crack is internal, scrap it. There is no heating involoved to distort your block with this method. If done right, it won't leak, will be strong, and can be easily ground down flush with the block. After painting, you cannot tell any repairs were made.<br /><br />Welding the block will weaken the area around the weld. Cast is very tricky to weld successfully. For a true cast weld. you would need to heat the entire block to over 800 degrees and then to let it cool evenly. Even after that you will need to have your crank journals line bored and trued. Then hope that your cylinders don't become warped.<br /><br />I'm sure if you spent some time searching different websites, you can find that block easily. There are lots of those available. Sometimes it is easier to find a whole boat that the hull is non-repairable to get the engine from. These boats are easy to aquire since the owners usually want to get rid of them.<br /><br />Good Luck
