This engine has a badly cracked cylinder, which also damaged the piston. Can a new sleeve be installed or is its life over? If I tear the engine down, can a shop replace the cylinder, then I can put it all back together, with a new piston/ring/bearings, etc.
I need to do as much as I can myself, since I can't afford to put it in the shop.
Thanks for any advice...
Jack
Jack
