Stacraft1768
- Joined
- May 16, 2015
- 17
Hey guys I am in need of some opinions here. This spring I started my boat up, and it ran great, i ran it for about a half and hour on the muffs, all while watching the temp gauge. Ran great, I then shut it off and left it for a few hours. That afternoon I came back and the darn thing was hydro locked, won't turn over at all, I pulled the valve cover and discovered milky oil...I assumed the worst. I took the motor out and disassembled it, and found that deep inside the exhaust passage of the second cylinder there was a dime sized piece of casting that had broke off exposing a water jacket. Can this be the cause of the milky oil? I have thourghly searched this block and head for signs of cracking and have found nothing. I removed the Pistons to check the cylinders they look great although the rings were pretty washed out and rusty. I am days from beginning the "fingers crossed" rering and assembly, I would like to get opinions. I haven't ruled out the head and head gasket but I will take it to a shop to get pressure checked and decked. Also the rod bearing and mains are checked and plastigauged.
