Cracked Head
deckbennett
My 2003, 4.3L GL-B Volvo I/O engine blew two pieces out of the head gasket. When I examined the head closely I found a crack in the head between cylinders 3 and 5. The dealer wants $675 for a replacement head. Has anyone replaced a boat engine head with a automotive head. The 4.3L head from NAPA is less than $200.
KJSmitty
Re: Cracked Head
I have not and don't really know if there is a difference (hopefully some one who does will chime in) - however,,,
Like you I would carefully be examining the NAPA head for fitment etc.. My guess is Volvo wants top dollar for their parts. Does NAPA have one so you can place the two side by side and compare? Most heads have a part number or something for ID - do they cross reference etc?
Just brainstorming with ya - but I would be seriously considering it as well..
deckbennett
Re: Cracked Head
Thanks for the input. I can check dimensions but I wonder if there is a difference in the valve guides since the boat engines run at higher RPM's. The NAPA heads come with the valves installed.
JustJason
Re: Cracked Head
Is that 675 for the entire job or 675 for just the head plus labor and all the fixins?
Is the dealers head new or remanufactored?
Is Napa's head new or reman'd?
deckbennett
Re: Cracked Head
The $675 is just for the head. I plan to do the labor myself. I think the Napa head is rebuilt but I will have to double check.
TilliamWe
Banned
Re: Cracked Head
The NAPA head will be fine. No major differences. Vortec heads are Vortec heads. Truck or boat.
180shabah
Re: Cracked Head
There is no super special magic marine valvetrain - just plain 'ol GM truck stuff. You will probably find the only difference it the VP head comes painted and has a waranty. NAPA warranty is likely void if used in a boat, but the casting is the same so.....
