HammondTiger
- Joined
- Mar 9, 2009
- 18
I changed my impeller this morning and noticed the lower unit has a crack in it. Can this be welded or will I have to start looking for a replacement?
I think my little brother backed it up onto something because the prop has a "ding" in it now also.
I have a friend that owns a Fab shop that says he will weld it for me. He said that all the gears and stuff will have to be removed first. What tools are needed to do this? Is it a fairly simple task?
The blades of the prop are not bent,it's actually the center hub on one side has a slight bend in it. No telling how long it's been that way. The boat stays on a lift in our boathouse. This is only the second time in 2 years that it has been "off" the water.Sorry to here about your lower unit. Wondering how long you ran the motor with a bent prop?
Have you taken off the prop to see if you bearing carrier is cracked?
