ct1762@gmail.com
Ensign
- Joined
- Jan 17, 2019
- 936
I'm putting together a 1985 70hp 49ci motor. the split bearing/race on the left is easy to wiggle side to side to the point were it almost touches the side of the crank. i know these are 2 piece split bearings with only a wire clip holding them together, but should they wiggle that much? its a few mm atleast.
i don't remember any of them this loose. it did take me an hour to line up all 3 dowel pins (had it in the first 10 min but then i took the crank out to double-check lol) so maybe i compromised that dowel pin were the bearing is loose by setting the crank on it a dozen times to get the bearings to line up? im probably just being paranoid as there isn't much lateral movement of these bearings when the motor is running, but better safe than sorry!
