Re: Crank case flange preperation?
Thanks Walker and R.Johnson. I have a couple more concerns to add also, if you gentlemen don't mind.........
1. Should I apply the Permatex Anaerobic Gasket Maker to the entire flat area and NOT just the outside peremeter? The OEM Service Manual doesn't really go into good detail on how this is supposed to be applied, although it does state to add a little extra to the outside edges. Therefor, I am assuming the entire flat area is to recieve the gasket maker, but I'm not 100 percent certain on this.
2. The service manual also states to apply the sealant 1/4 inch away from the "labyrinth seals". This leads me to my next queston......... What is a labyrinth seal? What, exactly, are they referring to?
3. In my discussions with Dhadley, I have learned he spreads the sealant with his finger instead of leaving just a bead around the flange. How thick, or thin, of a coating am I looking for?
Thanks a bunch guys!!!!!!!!.........................ALAN
